Anyone running P-Rated Ridge Grapplers (275/60r20) stock height
Team,
Is anyone running the P rated Ridge Grapplers?  I think I've decided to hold off on a leveling kit as I don't want to mess with swapping out my UCAs etc at this point, but I want to add a bit of rubber.  I was going to run the LT275/65 Ridge Grapplers with a level and figure the P Rated 275/60 will be a nice compromise.  Anyone running these on a 2017 with stock suspension? How's the ride?  Do they look like a watered down version of the LT RGs?
I ran a few searches, and the only set I've seen so far is on a leveled truck.
RHS
I ran 275/60/20 bfg ko2 on my stock rims on my 17 Sierra with stamped steel UCA's and would only have rub at full lock in reverse if I can remember correctly. Once I put my leveling kit in no issues with rubbing.
You could cross reference size of the nittos and the bfgs to see if that set up would work for you.
I ran Toyo Open Country AT2 in that size before I put my level kit on my 2015 Sierra with aluminum arms. Had no problems.
After I leveled it, I went with LT285/60R20. About the only run I get is at full lock in reverse.
Sent from my SM-N950U using Tapatalk
I'm not too worried about the size, seems that just about everyone who has tried to run this size without a level has been fine.  I'm more interested in the tires themselves.  Just pulled the trigger on a set, should have them mounted up in the next week or so.
  • 5 months later...
Interested in these tires as well. How have they held up? Got any pictures you can share?
  • 1 month later...
