My 2016 WT had better rear camera clarity then my 2017 SLE.... Still works, just looks like your'e looking through water.
My 2014 Sierra Camera sucked, the 2016 Sierra it was great, The new 2018 Silverado it's blurry again :(
Is this just a quality control issue with the Camera's?
I didn't realize how bad mine was until I test drove a 19, the clarity made mine look like a POS. I will say that the one on my 18 is better than the one in my old 15, so for me at least, they're getting progressively better.
We are talking about the back up camera, correct?  I didn't thing GM offered a rear view camera until these 2019's came out.
The back up camera on our Suburban is ok, but really sucks at night.
I could read a newspaper headline with my 2014 1500 Sierra camera (im exagerrating but it was very clear).  Just bought a new '18 2500 6.0 SLT and the rear view camera stinks!   Value engineering strikes again.....
  • 1 year later...
Anyone figure this out yet? I just bought a 2017 suburban premier thinking it was top notch, but the camera was garbage. My 2019 Ram looks 100x better.
I've had the same camera experience as others.  Had a 2014 1500  with a great camera.  I drove a 2019 old style 1500 for 2 weeks that had a great camera.  Bought my  2015 3500 and the camera was terrible.  So I took a gamble and bought GM# 84079952.  This is the replacement for a 2019 HD with 8' box and with out remote tailgate.  The picture is fantastic.  Only trouble was I had to swap the old connector (6 pin) onto the new camera (8 pin).  The extra 2 pins are for the power locking tailgate.
U mind posting pin outs, which is 12v+, 12v-, reverse signal, camera +, camera -. There are 2 grounds that are joined together.
Sent from my SM-G960U using Tapatalk
has anyone figured out how to access the rear view camera  without putting it in reverse? when i'm towing my log splitter it would be handy to be able see that it's ok back there. i've got a 2019 2500hd.
  • 1 month later...
84062896 camera VS 84079952?
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 519 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
