Added driver assist handle and trim won’t line up now (pic)
BillK01
Just a quick update.  The second driver assist handle came today.  So I removed the one that wasn’t fitting how I liked.  I then lopped off the guide pin with my oscillating saw and tried it again with no luck.
So I unboxed the new one and tried it.  Unfortunately it seemed to fit only slightly better than the other one.  After another 5 or 6 tries I finally decided that the welded on brackets the bolts screw into must be off a bit because as soon as the bolts start snugging up the entire assist handle slowly rotates down exposing the A pillar metal along the windshield.
I did my best McGyver and dug around in my toolchest and found a moderately thick rubber washer and cut it in half.  I then applied it to lower portion of the bracket and tried reinstalling the handle.  Bingo!  It worked.  There is still a tiny bit of the pillar showing but it’s much better than before and I can live with it now.  Having that thick rubber washer below each bolt seems to have kept the handle from rotating down once tightened up!  I wish I could have got it without all the fussing but at least it looks presentable now.  (Sorry again about the rotation.  I can’t figure out how to fix it.)
So does the handle have a little “play” in it with the rubber washer or is it solid? Looks good. Wish I had your Shark fin, mines black.
No play at all.  It was a pretty dense/heavy washer and the bolts both tightened up really snug.
On 12/12/2018 at 2:14 PM, O_J_Simpson said:
Post a video of you installing it and we can tell you where you are going wrong. It will never be perfect as there is often a small gap at the head liner but should never be that bad.
I have a gap on the top of mine and was wondering if I can take a heat gun to it and try to close it up a little. Any thoughts? Of course I would remove it first and go by trial and error. Is it even worth it?
Mine was off the first couple tries. Key to fixing it for me was getting the little lip by the window to snap into place first. Once I got it to snap all the way down it went on perfect...no wiggle and no gap.
Just Installed this to my truck, fit perfect with no gap. I did not cut off the alignment rod either.
What’s the part number for your driver side assist handle? Need same color as yours. Thank you.
Part number: 23285089
Yes, thank you! I’ve got about 1.5 feet I need to try and shimmy my way out of the truck when parking in the garage so I think I need this handle. I’m not as flexible as I used to be! Over 40 sucks. Ha!
Oh yeah it does..LOL! I find I use mine every time I get in or out (I do have a 2.25 level so it sits a bit higher) and I think it will help with seat wear too! Mine went in without any gaps or fitment issues so it sucks there are some that are having problems...
I think it will definitely help with seat wear. I had my lower seat cover replaced in my ‘15 because it split in “the spot” and I don’t want the same thing to happen in my ‘18. Hopefully it lines up after install. I’ve been following this thread so we will see!
Dang, I think that’s for the more tan color. Mine is the gray(ish) color. Nothing a search won’t find for me! Too bad it’s too late to cancel the Amazon order. At least they make it easy to return! Live and learn. I was too punchy on making that purchase.
Edit: looks like the gray part number is: 23285090
Yep, that's the gray one. You can find it cheaper than what is on AMAZON.
On 12/11/2018 at 7:09 PM, BillK01 said:
So the second thing I did to my new Sierra 1500 is add the driver assist handle like is in the passenger side.
Everything went smoothly and I was happy until I looked at the truck from the front and noticed some of the interior portion of the A pillar is now exposed and the edge of the new handle doesn’t cover it.  I have had it off and on 5 or 6 times tryin to get it to line up with no luck.  Has anyone else had this experience?  Attached is a pic of what I’m talking about.  Sorry the rotation is funky.
I had similar problem with 2 different handles on my Silverado. Wasn’t a snug fit at the top. Finally had the dealer do it and fits like a glove.  I’m guessing snapping in windshield edge first does the trick.
BTW I’m willing to send anyone one of my 2 ‘rejects’ if you cover shipping (Part# 23285090).  PM if interested.
    Enduro73
    Enduro73
  • Who's Online   3 Members, 0 Anonymous, 1,243 Guests (See full list)
