This write-up is for a 2017 Chevy 2500hd 6.0l Flex Fuel.
I decided to install the Whipple Supercharger system on my truck. The Supercharger Kit comes with very quality parts that are precision made. Now, the install manual needs some definite editing due to missed steps and steps that can be performed ahead of time to save interruptions in the process.
I am editing the instruction manual to include time saving steps and will post it when completed.
The kit for my truck took 2 days which is not out of the question if your being careful. The kit includes a HP Tuners MPVI-2, supercharger w/ intercooler, intake manifold, fuel rails, heat exchanger, reservoir tank w/electric pump, new belt, tensioner with idler pulleys, MAF sensor to throttle body hoses, new 160-degree thermostat, and all the hoses and electrical wiring needed. It is a little overwhelming when I first laid it all out, but once underway (with so so instructions), everything seems to just fall into place. Granted, I have been a mechanic for over 40 years, but a person with less time can surely do this themselves with patients.
This kit uses the stock airbox set-up with a high flow filter. Other than that, most everything is new install.
The kit uses the stock fuel pump and injectors. These items on the flex fuel are more than sufficient in supplying fuel to the engine.
The very first thing I did was read the stock files in the ECM with the HP Tuner program, then I sent the log file to Whipple via email and within 1-2 days, I received my new tune for the truck for after the supercharger install. The next steps were to drain the coolant, and begin to remove components such as: stock intake manifold, alternator, fuel rails, stock belt tensioner and idler pulley, plus more.
There were a few hiccups that occurred during the install. The kit included an older wiring harness that I had to adapt to my truck, (this truck is my daily driver, and I couldn’t wait for the correct harness), older fuse tap, defective MAP sensor (GM part, which is installed before the intake manifold due to the location on the back of the engine), and the intake bulge pipe did not fit correctly. Other than these shortcomings, the install was not very difficult. The install of the heat exchanger and reservoir tank w/ circulation pump were a little confusing and time consuming, but with proper instructions, it should go easy.
Once everything was installed, I programed the truck for the new tune. I have been having issues with the tune. After speaking with a professional tuner, I discovered the computer for the 2500/3500hd 6.0L is only used in these trucks. The tuner explained that tuning these trucks are a PITA. I have an appointment on Friday to have mine dyno tuned. The shop that I am using does quite a bit of work with Whipple and actually makes a good number of their programs.
After that long-winded explanation, I do have to say, the low-end running issue I am having trouble with gets ironed out on Friday, but the Whipple Supercharger is an amazing product and makes amazing power. I will know more of exactly how much power it is making on Friday. I can say that 20 mph to 110 mph happens before you know it, and with a wide-open throttle, you will be forced into your seat.
I will update and answer any questions.
What trans? And map is relocated to pre charger? How does it see boost? Is your tuner using your credits to tune? Interesting it has a lower thermostat. How much boost I want to guess the dyno number.
Yep.... this is the exact reason I advise against working on these gas engine HD's since 2011.  I have a cam for mine but I am not installing it.  I have ghost timing issues I can't fix on the stock tune.... let alone start really messing with airflow and the VE table.   Not to mention I can completely re-write a table and it doesn't respond to the changes lol Two guys I have read write ups on tore their blowers off and sold them.  One used a Magnusson kit and it never ran right with part throttle surging.  The other used a CTS V blower and had more or less the same issues.
Hopefully you get it to work and there is some hope!  I don't know if HP has updated anything for support in any of the new releases but I have my doubts with such a limited market.
Edited by SierraHD17
Not totally sure what you mean but it being an hd means its still the LS based motor if i remember right. Not thr LT platform like we have
E78A ecm.  Look it up on HP or Efilive and realize there is diddly squat for support for it.  No it's not like tuning an E38 or an E92.  It looks the same table wise as an E92 kind of but you are lucky if the table actually works.
He's an L96 6 liter with a 6L90e like the rest of the HD's.  Should be in the HD truck section of the forum and not the half ton stuff.
I am anxious to see what this tuner can do. He does tunes for Whipple and HP, but he designs his own tunes. He and his crew on occasion tune for NHRA drivers, so he is very capable. I will not talk bad about this product until I have the expert work his magic.
Glad to see the follow up, would love to go this route to avoid looking for a deisel. I tow 12k lbs, and could use some more tq n hp. Looking foward to the follow up posts. Where did you get the kit from???
Sent from my SM-G960U using Tapatalk
If you need a HD get a Diesel. Don't get me wrong I love some LS and boost . Had plenty. Now have a 6.2 with 8speed and contemplating another build.
Good luck and keep us updated
Sent from my Pixel 3 using Tapatalk
I have attached the Dyno Results from my Supercharged Silverado. I hope you can all see that this engine and ECM have the ability to be tuned. I am very capable of installing this kit, but leave the fine tuning to the experts. Some may think they are experts at tuning, but use a reliable source, you will be extremely happy with your purchase.
By the way, these dyno results were the next to last run, the final numbers were  438hp, 429lb-ft.
After the dyno tune, it was determined that I need to install a JMS Voltage Booster for the fuel pump. The proper voltage should be between 14-17 volts, but intermittently, we observed 11-12v which is not allowing full power, so it will be interesting to see what the total HP will be with the booster installed.
Dyno Tune 12-21-18.pdf
12-21-18 dynochart1.pdf
12-21-18 dynochart2.pdf
Edited by Biggerdogg01
  • Thanks 1
Were you using the stock 6ish psi pulley? Great numbers
1 hour ago, cmysstailights said:
Nice gains. This was on stock injectors and stock fuel.pump? Wonder what my numbers would be on e85 and headers.
Yes, stock injectors and stock fuel pump. The flex fuel injectors flow very well, no need to change and the fuel pump will support up to 800hp.
The pulley is the one they include, it is a 3.625", and yes, 6ish boost.
Thats awesome. I bet youre happy
Lets put it this way, if you are traveling at 30mph and hold it WOT, it has so much pull it is a little un-nerving. Scared the wife today when I did it....lol.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
