Kgonzalez Posted December 28, 2018 Posted December 28, 2018 Have a 2015 2500HD LT. It's a crew can with bench seat. The cigerette lighter that's on the back side of the bench accessible to back seat stopped working. Basically was in a Xmas parade and used a converter to run Christmas lights for a float. I guess it wasnt big enough or something. Worked for 20mins or so then suddenly lights cut off. Went to pull converter plug and it was melted. Now the cigerette lighter will not work. Pulled every single fuse on driver side AND passenger side of dashboard fuse panels and nothing blown. Pulled a bunch from under hood and again nothing blown. What am I missing??? Any ideas?
diyer2 Posted December 28, 2018 Posted December 28, 2018 Take it apart. May have melted the wire or the cig plug.
JimCost2014 Posted December 29, 2018 Posted December 29, 2018 On 12/27/2018 at 8:58 PM, Kgonzalez said: Have a 2015 2500HD LT. It's a crew can with bench seat. The cigerette lighter that's on the back side of the bench accessible to back seat stopped working. Basically was in a Xmas parade and used a converter to run Christmas lights for a float. I guess it wasnt big enough or something. Worked for 20mins or so then suddenly lights cut off. Went to pull converter plug and it was melted. Now the cigerette lighter will not work. Pulled every single fuse on driver side AND passenger side of dashboard fuse panels and nothing blown. Pulled a bunch from under hood and again nothing blown. What am I missing??? Any ideas? Try this post on the site, older trucks, but sounds like the same problem. Aux Power Outlet Not Working
Kgonzalez Posted December 30, 2018 Author Posted December 30, 2018 Ok So I literally just took every fuse out of all 3 fuse blocks. Passenger side of dash, driver side of dash and under the hood. Also popper the rear cigerette lighter out and checked wires coming out the back and they looked good but did not trace them all the way forward ?♂️?♂️?♂️
JimCost2014 Posted December 31, 2018 Posted December 31, 2018 5 hours ago, Kgonzalez said: Ok So I literally just took every fuse out of all 3 fuse blocks. Passenger side of dash, driver side of dash and under the hood. Also popper the rear cigerette lighter out and checked wires coming out the back and they looked good but did not trace them all the way forward ?♂️?♂️?♂️ Did you check the wires to the plug to see if you had power coming through them. I would probably plan on replacing the plug.
Kgonzalez Posted December 31, 2018 Author Posted December 31, 2018 No. I dont have a tester. Will need to pick one up tomorrow
