Nitto Sale
bhales
FYI Nitto sale going on right now on Tire Buyer.com 10% of Nitto tires i jsut ordered a set of 295/60 20s for my 18 SLT for $1246.25 shipped to my door. Ill post pics once the level and tires are on
ORDER TOTAL
(due today)
$1,246.25
Thanks for the heads up!  Have you used tirebuyer.com before? They also do a 7% military discount, but doesn't look like you can stack the discount codes.
My ridge grapplers have about had it,over 60K on them... probably can get 5K more out of them before they are on the wear bars.
yes i ordered a set of tires for my wifes acadia from them before ship to installer no hassle
They ran the same deal a month or so ago when I ordered my RGs, by far the best deal out there. I had never used TireBuyer before so I swung by the local shop I planned on using prior to ordering. Just out of curiousity, I had them price out the same tires and they were $70 higher per tire!  Shipping was quick and the shop had me in and out quickly.
I saw the sale prices and showed the discounted price go my rep at Discount tire. I've used them for years. They instantly price match so I could also get the certificates in case of irreparable pops or premature wear
Sent from my SM-G950U using Tapatalk
Ordered my RidgeGrapplers from Tirebuyer the week of BlackFriday. Had them at my door in two days and had them mounted. The shop had a hard time road force balancing 3 tires. I called Tirebuyer up and they immediately shipped me 3 replacement tires. I completed the supporting paperwork and shipped the tires back to them with the provided return labels. Easiest transaction ever. The 3 new tires all road balanced with no issue.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 182 Guests (See full list)
