Memory Seat setting...No Beep...No Set
trammd
I didnt see a fuse anywhere for "memory seat function"  in the left front fuse panel. I only see a fuse #41 for the Drivers Power seat. (the power seat functions fine)
Can anyone help me locate the fuse for the Memory seat function?   Thanks!
Power cycling the battery didn't fix it......Can anyone tell me if the memory seat switch is supposed to be backlit like the other door switches?? Mine is NOT. Thanks.
Yes, it does light up with the other interior lights
I am trying to check the plug on the back of the switch. Is there a trick to getting the door pull trim ring out that houses the switch? I removed the 1- 7mm screw behind the cover under the door handle. I hope the whole door panel doesn't have to come off!
Hi, does anyone know if there is a fuse for the door switch that controls the memory seats in my 2014 Silverado LTZ Z71?
I have NO functions and the backlight doesn't work on the switch. This is a brand new switch, I just replaced it as I was thinkinking the switch was bad but now???????
Where and what # fuse is it?
The power seat functions fine....Just no memory functions and the switch does not light up so maybe fuse related???
Thanks!
11 hours ago, trammd said:
Jimcost2014....you mentioned a fuse.
Do you know what fuse and where it is located? Thanks!
I believe there has been a problem with this, I think it would be the fuse that powers the heat function for the power seats also. Have you popped the lid on the fuse box in the engine compartment?
I replaced the switch with a new one.  Wiring looks good. Did NOT resolve my issue. Still NO switch back light, NO functions, NO beeps. Has anyone else dealt with this issue?
The switch is obviously not receiving power and/or signals from whatever controls it....
  • 11 months later...
    B07
    B07
  • Who's Online   3 Members, 1 Anonymous, 955 Guests (See full list)
