I have a 2014 Silverado crew cab 4x4 LT when I make a phone call using Bluetooth when I call people I can hear them but they can't hear me
when I talk I replaced the shark fin an I also replaced the mic in the  roof of the. Cab an still nothing
Welcome to the site. I take it worked before the new parts, maybe un sync your phone and then re pair it to the truck. You could also disconnect the battery, let is sit for 30 minutes and then connect it. This helps with a lot of the electrical problems.
Thanks for letting me join but I tried everything . it all worked before I had my windshield replace so I thought it was the shark fin replaced didn’t work replaced Bluetooth mic didn’t work paired unpaired phone an still nothing
Do you think that when they replaced your windshield they could unplugged/cut a wire that goes to the mic? Post a picture where the mic is and what is around it. Do you have the ability to see if you have power coming to the mic?
Thanks for the reply .There’s nothing around the mic an has power the shark fin xm Antonia works fine it’s on the same side I’m going to drop the headliner again on the passenger side an see if the harness is pinched or something on that side
Hey, I have a 2018 Sierra SLE 4x4 half ton. It’s fully loaded other then leather. Recently I switched from Samsung to the new I14 mini IPhone. I synced it ran the new contacts and everything was good. Then one day I hooked the phone to the centre council and it asked to update the new IPhone sync. I excepted the update and since my mic stopped working. I can push the call button and it asks me the usual. But when I tell it who to call nothing happens. So I tried calling direct from phone and I hear it ring, and the other people but they don’t hear me. What’s going on and how do I fix it?????
    Bert 22
    Bert 22
  • Who's Online   4 Members, 0 Anonymous, 678 Guests (See full list)
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
