Range device or Tune??
Get a range device or go ahead and get a tune?? What are you guys doing?
2018 Silverado CC 5.3L V8
  • Replies 51
What mods and what do you use and 2ant your truck for. Tune is better but if all stock and no future wants. Warranty concerns?
There are free stock tunes available on HPT. And forums help.
I’m not running any engine mods so I’m just doing the SuperChips F5 Tuner which I used for HP/TQ as well as turning off AFM, speed limiter and adjusting tire size which makes a big difference. I’ve noticed an improved mpg and raised the throttle response that was taken away when added larger tires.
Sent from above
Sent from above
I also used the superchips to disable the afm, adjust the tire size and transmission shift points. I didn't need a full custom tune since the truck is pretty much stock but allowed enough customization to make it a great in the middle tuner.
Agreed
Sent from above
If you do have a Custom Tune done. You will never buy a Handheld Canned Tuner again. Trust me
Sent from above
2 hours ago, jackgraves said:
Custom Tune All The Way
1 hour ago, TXGREEK said:
Agreed
Sent from above
I stopped by my local accessories shop and they gave me some info on the superchips.... which piqued my interest because it didn’t sound to extensive.
Right now the truck is stock... but I have plans in the near future (extremely near lol) to add:
12.50x33R20 tires
wheels
Leveling coil overs
CA intake
and exhaust - not sure on what yet.
Although the 4” lifts are really catching my eye.
12.50x33R20 tires
wheels
Leveling coil overs
CA intake
First time I ran a 2.25” level was to be able to get into my garage. It was horrible decision, it caused my tires to rub then having to buy new wheels finally leading me to do the awesome CST 4.5” Lift. It actually lets me keep my stock track width and turning radius as well as let’s me keep stock wheels if I wanted to and the suspension is still stock geometry not requiring any additional modifications to your suspension, super high quality and heavy duty lift with exceptional craftsmanship second to none. The ride quality is great going from leveled to this lift, much nicer and smoother.
Here’s when leveled
Here’s CST 4.5” lift
Running 34” Nitto Ridge Grapplers. CST front coilovers and rear piggyback resi’s
Best of all, it fits in my garage, check them out
https://cstsuspension.com/
Sent from above
Only thing is that no one has a tune for my 8speed transmission yet which would be a complete waist of time and money. The canned tune is (IMHO) a safer route especially since the vehicle is still under warranty. If I ever decide that I want more from my engine, I’ll have a supercharger installed and the rest will be history, literally [emoji6]
Sent from above
If you actually want a "tune" this is true....a superchips tuner or similar is just a good way to alter stock settings. You shouldn't buy it with true power increase gains in mind.
Sent from above
What do you mean no one has a 8speed tune? 8speed tunes are available and have been for a long time.
No one offers a tune for the 8speed in my 18,6.2. Checked all the canned tunes, not avail yet
Sent from above
I'll just break down the superchips f5 capabilities
It combines multiple devices in one:
Tire size calibrator - hypertech speedometer calibrator
Pedal voltage adjustment - Pedal Commander
AFM Disable - Range Device
Adds the ability to change:
Shift point adjustment/speed/rpm for the 6-speed trans
Shift torque management
rev limiter
speed limiter
gear ratios
adjust tire pressure monitor
idle/drive rpm
read/clear DTC
monitor gauges
Mileage XS/87/93 Tunes - canned, not vehicle specific tunes.
I ended up getting mine new/used for 170 bucks so it was a no brainer. I did not intend for it to be used for performance gains, if performance is what you are looking for then you want to put the truck on a dyno and do it right with someone to custom tune your vehicle. Even what you download from HPT may be "custom" but its not for your truck, every vehicle varies.
