Split the infotainment screen to show nav and music?
I did something to my AT4 infotainment screen to have it split to show both audio and nav (each on half the screen).   I can't figure out how to make it do this again.   I do not have my "infotainment manual" handy.   Does any one know how to do this (or have a link to a pdf of the infotainment manual)?   This might make a good addition to the "post cool feature discoveries on your T1" thread.   If my 2016 sierra had this feature then I never used it.
57 minutes ago, wrutherf said:
Swipe to the right from the "home" screen
Also, once at either of the home screens the soft and hard home buttons will toggle between the two views.
-Dave
Is this only availible on the 2019 models?
My 2013 avalanche NAV can do it...
Sent from my SM-T580 using Tapatalk
  • 3 weeks later...
Have you tried turning down the brightness control on the left hand side of the steering wheel? The unit also has a Display Mode under Settings > System > Display > Display Mode.
There was a glitch with my loaner where the screen wouldn't dim at all with the automatic lights. If I cycled the headlight switch from "auto" to "off" and back to "auto", it would then turn it's brightness down as it should. If yours isn't dimming at all, I would try that. Obviously it's not a fix but at least a temporary work around.
1 hour ago, Rduatctt said:
Yeah, but still bright
Does the Brightness Control work for any Dash Lights with the Light Switch in Auto or Headlamps ON while it is dark out?
I'm having a similar problem with my Trail Boss only it is the opposite, too dim during the daylight, can't see screen very well. If I cycle the headlight switch to off and back to auto it will brighten. Night time brightness is not a problem for me.
Same here with it being Dim in the day. Didn't really notice it until this weekend (first time in a while sun was out). Dim such that it was hard to read - almost like it was set to be dimmed when the headlamps are on.
  • 1 year later...
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   4 Members, 0 Anonymous, 928 Guests (See full list)
