Black Lugs
Bigshu
Hey all.  Looking for some help on finding black lugs/wheel nuts for my 2018 2500 HD Midnight Edition.  Just starting to mod and want to replace my factory lugs with black ones. Went to O'Reilly and ofc they gave me the wrong ones. Factory style is fine just want black and good quality.  Not a big tinkerer so would rather not powder coat my own.  Using on my factory rims.
Thanks in advance.
Thanks in advance.
I had my local tire get some for me . ANY good Tire shop should help you.
not all lugs are created equal - had some black ones on my Z06 to match my powdercoated wheels & they started chipping almost immediately, & depending where they're made could be cheap grade steel - while not apples to apples I've had chinese knock off sockets split in 1/2 under stress.....not good.
I have a set of Mcgard black lugs on both my truck & my vette & they're noticeably better quality than what you'd get at your typical auto parts stores - guaranteed not to chip/rust & can be used w/ impact gun. While i hand torque my vette lugs myself & use a wrench coated in electrical tape (I can be OCD) - my truck gets whatever treatment my local mechanic gives it probably use impact guns & drop the nuts occasionally etc. + I run them on my winter wheel setup so they see alot of road salt/sand & still holding up well.
Mcgard made in the US too which is a plus - Dorman & Gorilla I think are also decent quality
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
