Dealer Offered Paint Protection
Nearing a decision on a 2018 Sierra purchase and have a question re: paint protection.
Does anyone have feedback on a product called 'Ultimar' ?
I couldn't find any search results here and there seems to be few Google search results via forums. Only see a dealership's video demo of spraying paint on the hood of a vehicle in their showroom and wiping it off... with some effort.
Considering an Onyx Black Sierra and never having owned or cared for such paint on a vehicle in the past... concerned about it's up keep with bird droppings, tree sap, etc.
In the past I've always passed on these 'up-sells' ... but am looking for the best way to approach the pre-emptive care for Onyx Black paint... :D .... as well as the others.
  • Replies 32
In the past I've always passed on these 'up-sells' ... but am looking for the best way to approach the pre-emptive care for Onyx Black paint... [emoji3] .... as well as the others.
What's the price to the paint protection they're offering?
Sent from my SM-G955U using Tapatalk
Are you talking a ceramic coating or paint protection film
$ 699 ....
For that price I would get the truck paint corrected and ceramic coated instead
From what I understand... it is 'surface protection' as referred to on their site.
Nothing mentions 'ceramic coating'
If it where me I would pass of their "paint protection" and find someone who would get you a good ceramic coating done.
The feedback is much appreciated from all !
I'm not up on ceramic coating's ins and outs... anything special to be aware of when contacting local detailers to have it done?
Send me PM. I'll get into more detail there.
That what I am going to with my black 2018 Silverado.
Just so you know if you've never owned a black vehicle......Black is not a color , it's an occupation.
Looks great as long as you have the time to devote in caring for it.
Looks great!... and yes... the time it requires qualifies as an 'occupation' to keep it looking like that  :thumbs: .... from everything I've been told.
Same here. I'm going to give my paint some much needed attention after neglecting it for a while
Agree pass on that 699.00 sealant as said get the paint corrected and Pro Ceramic coating applied .. not cheap but it you want a lasting coating on a black paint only way go
I have G Technique Crystal Serum Ceramic on mine after paint correction since new
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
