Bulbs for overhead console
Penguin VII
I'm wanting to replace my overhead console lights with red LED lights (the ones that turn on when you open the door) and for the life of me I don't know what the size is or how to find it out. Not sure if there is a recommended brand, etc.
I prefer the red as it preserves your nightsight better and I use my overhead lights often at night. Thanks for the help!
Film would work as well, I figured there had to be some LEDs out there I can swap to. I only worry about the film against the halogen bulbs with the added heat reducing life on the bulb or burning the film.
Anyone know where I can find the bulb size? There has to be replacement parts which means there is likely a bulb replacement available. In that case I could switch to LED and add film if that is my only option.
Wow, I literally used the search function like 3 times looking for this and never saw it. God I'm blind. Thanks! Ordered some gel, good to know they are LEDs, will be a pretty easy fix.
the film i'm using is for the old school spot lights (they get stuuuuuuupid hot) used for lighting a stage... the film take take the heat no problem
Yeah, just ordered some. At first I was thinking depending on the film it might not, but those things are crazy hot so no little led will ever get that hot.
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 635 Guests (See full list)
