What a weekend
Jersey Tahoe LT
Well it al starts out on Friday. I take off of work to help a friend move into a new appartment. All was fine except that I help move everything to go back to my parents house cause I have no money to move out. Then Sat was fine cause I had a family get together to celebrate my cousins compleation of her teaching masters degree. So Sat was good. Then Sunday I wake up at 10am and I decide to finally Zaino my truck. So I spend 8 hours to finish the application. No big deal but I never get to see the finished product in the day light. And today when I woke up it was raining so I spent 8 hours to polish it for rain. Not bad but depressing. Then tonight I broke up with my girlfriend. I have wanted to for a few weeks but finally felt it was time. But it still makes you feel crappy. Well to say the least it was a bad laborday weekend. At least I get to go back to work tomorrow. Oh and I start School tomorrow. Nothing but fun. Well I hope you all had a better one than I. Thanks for listening.
Later,
Brandon
So your single and have a good looking truck...what's so bad about that? Heck, I spend about as much money on my truck as I did with my ex, heck, probably more. You can always find some good looking chicks at school. Good luck with it! :smash:
Pick that chin up and hold that head high! It'll get better bud! :smash:
If it makes ya feel better I had to work all through the weekend and Labor Day too. See you prob feel better already! :(
This is the first labor day in as long as I remember that I didn't labor. I can agree with you somewhat as to being down, had 2 good dates while out of town on vacation, note the "Out of town" part...story of my life, can never get all those ducks in a row.
I never got around to fishing which really sucked. My cousin's dog, a huskey who kicked ass, was killed. My great aunt had to spend some time in the hospital as well. So it kind of sucked for me. Not very easy to celebrate labor day either when much of your family is at risk of getting laid off too (or is already jobless).
