I have a 2015 Chevy Silverado single cab short bed work truck with the 4.3 liter that the power steering unit just decided to quit working while prerunning in Baja with my wife. It wasn’t an issue but my triceps got a serious work out. I took it into Bob Stall Chevrolet in La Mesa California and found out that the ECU and the EPS weren’t communicating. Of course this isn’t covered by the warranty and it was $1,100 for the new EPS and $800-$1,300 for the labor. The gremlin of Offroad racing usually ends up being an electrical issue so I decided to ditch the EPS and go with the older more reliable Hydraulic Power Steering Steering. In order to do that I ordered the Dirty Dingo Power Steering Conversion Brackets, Dirty Dingo LS water pump adapters, LS water pump, 1996 Chevy Silverado Power steering pump, 2006 Chevy Silverado hydraulic rack and pinion, and Corvette vacuum pump block off plugs. All the parts finally arrived today, and I’ll be starting this project and hopefully be finishing before the weekend is over.
DD Conversion Brackets
https://www.dirtydingo.com/shop/mobile_product_info.php?products_id=1750
DD Water Pump Adapters
https://www.dirtydingo.com/shop/mobile_product_info.php?products_id=1583
Corvette Vacuum Plugs Part # (order 2)
11546665
LS Water Pump Part #
89018052
Power Steering Pump Part #
7312138
Steering Rack Part #
2210003BFCF27B-24C1-434E-9C81-4318D3AFF3AD.thumb.jpeg.0023338bb576c06015525aab7b447902.jpeg
Sorry but why. There is tried and true systems. Full hydraulic systems that are stronger then coffin nails. And half the parts.
Electronic power steerings a joke. The steering rack and pinion is temporary, I’m designing a swing set full hydraulic system with a Howe hydraulic ram. I’m going to need a power steering pump so this is a step in the right direction for me.
After battling with the hydraulic power steering in my 93 C1500 years ago, having electric power steering is a godsend to me. My problem was that the only pumps available to me at the time were remanufactured and one summer I changed that pump 4 times in 3 months. I could still, to this day, change out the pump in that truck blindfolded. I did it probably about 7 or 8 times total in the years I drove it.
The hydraulic system in my GMT800 Tahoes was pretty stout. Never an issue, but eventually they'll spring a leak.
I don't drive Baja though. [emoji2369]
Sent from my SAMSUNG-SM-J727A using Tapatalk
I agree. Buy yourself an AM only radio too, in case the modern stereo goes out.
If it were a daily driver I’d get the electric power steering completely. But several of my buddies also had EPS fail on there trucks that never hit the dirt. One of them had to change out the whole rack once and the motor twice. Every auto parts store has power steering fluid and some sort of power steering line I could mcgiver. But a Snap in diagnostic machine is a little tougher. This is my fix to the the problem, other people have there’s and I respect that! Thanks for the reply
There are ways to harden electronics to shock and vibration, I assure you. And we've done it with systems that are far more complex than a power steering system.
Haha I have racer x intercom headsets in the truck just in case that happens!
 Agree with you 100%. I’m going to something I know just for the simplicity of it and what’s been proven in Offroad racing since it started.
If you have sponsors with deep enough pockets, I bet that I and a couple hand-picked guys could design and build you an electric one that's Baja-worthy! [emoji106]
2 minutes ago, HeySkippyDog said:
If you have sponsors with deep enough pockets, I bet that I and a couple hand-picked guys could design and build you an electric one that's Baja-worthy! emoji106.png
No sponsors or deep pockets? I know Polaris RZRs have EPS but I haven’t seen a desert truck with one yet. It’d definitely be cool to make it work
No sponsors or deep pockets[emoji23] I know Polaris RZRs have EPS but I haven’t seen a desert truck with one yet. It’d definitely be cool to make it work
It was worth a shot! Good luck on your project.
I would be very leery of using 90s truck parts though. The trucks then (1500s) were not as heavy as they are now.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
