i cant find the part number for the door panel screws and i don't see them on the parts break down
apparently previous owner broke one off
anyone have a link or a number?
55 views and no one knows?
I tried just doing generic searches for the screw and i cant come up with anything. I may just go to the dealer and see if they can figure it out.
Yes. Go to the dealer. You will most likely have to buy a pack of 10 though. They are expensive.. or find them in a rental truck and take em out.
Not sure if anyone needs to know this but just ran into this issue on my truck. GM PN for the bolts is 11589015. They’re a M4.2-1.41x20mm bolt. Also Dorman makes a replacement if you don’t mind the pointed tip. The Dorman are PN: 964-005D. They’re a bit cheaper. Also they’re the same as the gauge cluster bolts.
Edited by Ryanncook
