Odd Tire Wear
So I’ve got KO2s on my truck, 31k miles on them, and rotated every 6-10k miles.  Truck has coils spacers up front and AAL in the rear.  Tires are 275-55-20 lt running 48psi.
 I’m assuming the truck is out alignment, causing my problem. They are worn a much more on the outsides, and the insides look almost new.  I’m wondering if I should have them taken off the rims and flipped so the outside becomes the inside?  Then align the truck? Or just flip tires and leave the alignment alone? I’d like to get 1 more winter out of these, but as it sits I don’t see that happening.
I will definitely align the truck when it’s time for new rubber.  Plan was to get either new ko2s or general atx fall 2020 (pushing 50k on my current tires at that time).  Probably go up to 285-55-20s for the next set.
Sounds like your TOE is out of spec and you need an alignment.
When I installed Bilstein 5100 on 3rd setting (1.75") of lift, my TOE was way out of spec and would have chewed outside of front tires. Truck seemed to drive fine
I would take it in now to get alignment checked. Would help to flip tire on rim if non directional or at least rotate front to rear.
38 minutes ago, jaxcam02 said:
Do you take corners aggressively?
Yes, I’m sure that’s part of the problem.
I’m sure that the toe alignment is out of whack.  I’d bet when the previous owner installed the leveling spacers it was not realigned. I, like an idiot, didn’t bother to check or have the dealer I bought from align before purchasing.  All four tires are like this at this point.  I’m concerned that since they are so worn the they will force the truck back out of alignment if I just do that.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
