  • 10 months later...
I kept stock wheels. Running 285 65 20 just fine.  The shop added a spacer up front.
I am running 35's with the 4" lift on the AT4. I am rubbing also with minimal flex into turns. Rubbing in the same spot as OP. Fenders are trimmed. It is only rubbing on the passenger side. I have also noticed the passenger front tire is about 3/4" closer to the fender than the driver side.
  • 5 months later...
too much poke, I can fit a 35 on a stock wheel, no lift since it has a very conservative offset.
Edited by OpsWest
  • 9 months later...
On 4/12/2019 at 10:52 PM, Antonio Kheir said:
Hey guys. Just made an account! So my dad just bought a 2019 Sierra AT4 and installed a 6” RC lift with 35” ridge grapplers on a 22X10 wheel with 1/4” backspaces. He has the gmc brembo upgrade kit. He seems to be rubbing on the outer front fenders while turning with minimal flexing. I don’t have the specs for the offset nor the backspacing  yet. I will be getting that info tomorrow. Any ideas on what he needs to do to minimize or eliminate the rubbing? He put me in charge of figuring this stuff out haha. Thanks!
If your dad still has this truck could you ask him to measure what his roof height is? Trying to do the same setup but stay under 7'
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
