Anybody Have BlackBear Tuner Issues???
Has anybody had any issues with BlackBear Autocal that was not a user problem? Anything specifically pertaining to ECU lockup? I heard about that happening on an 8 speed dodge but was okay on the 6 speed dodge.
From what I hear and what I read, blackbear is the way to go. Mostly what I am looking for is drivability and to tighten the hell out of my transmission as I just put a new one in. Other things id like to take care of is the Active Fuel Management, Torque Management System, and change up my stabilitrak/TC preferences.
Im not so concerned with running e85 or premium tunes as what I can tell being stock it really won't make a huge difference in engine preservation.
Does anybody have any experiences or knowledge to share for what I will see in the future choosing BlackBear, or maybe some suggestions to add to my list for Justin?
Thanks guys
Have the auto cal Blackbear tune on my 015 since 016 put 3k miles on my truck new off the lot then had them tune it. I’m perfectly content with it knowing there are better/more advanced options out there.
After you get your base tunes to them they will ask you what you want from your tune/truck and what mods you have. Just tell them what you are after here is what my email to them said to give you an idea.
MODS
Airaid MIT tube, stock airbox, Delco air filter
Flowmaster 70 series muffler, exhaust valve/resonator delete
TIRES
285/70/17
TUNE
AFM off
speed limiter off or raised
I would like the transmission to "hunt" less not sure how to explain the up shifts are soft/slow but I don't want it to bang/slam like a shift kit. At slow speed (parking lot/off road) it seems indecisive of which gear to be in and downshifts are jerky. I don't like when I go around a corner let off the gas then step on it and it's like there's nothing happening not sure if that's the tranny or torque management? So whatever you think for the trans and TM.
Around here 87/91 octane is the norm it's about impossible to find 92 +
I do occasionally pull a car hauler 6,000 pounds or a quad trailer 2,000 pounds
driving is 70% highway, 25% intown, 5% dirt roads
live in Iowa so weather is both extremes if that matters
I drive it like a "old guy" 90% of the time it's a truck not a Camaro SS so not looking for "MAX power" just better drivability if that makes sense.
Thanks
The auto cal has five slots. 2 are for your stock tunes engine/trans then 3 for your tunes. Mine is a 87 tune, 91 tune, and trans tune. I installed my 91 and trans tunes when I got them and haven’t done anything else since except drive it. Just a FYI summer E-85 really wakes up the engine with the 91 tune. ?
IMO the truck after both tunes drives/shifts like I thought it should have from the get go 95% of the time anyway. I still get a funky up/down shift every now and then under certain situations.
I bought my auto cal and tunes on sale (Black Friday) 100 bucks off from them so I’d check for similar sales with the upcoming holidays. Might save you a couple bucks?
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
