Has anyone removed one I’m a little hesitant
I removed the top cover with all the pushpins
Four bolts on top and that’s as far as I got
Had a hard time locating the remainder of clips that hold it in place I was afraid to pull too hard thought I was going to Break something
I've removed mine. After you remove the 4 bolts, lift up on the top of the grille to release it from the top support then pull hard. It won't break. Catch end ears by headlights and pull.
Wait... there are no bottom bolts on the grille on the 19 Sierra?  No lower tabs that have to be released first? You don't have no remove that whole front trim piece that goes under the grille, headlights and over by the wheels?
I am pulling mine on Saturday to install siren speakers and lights in front of the vents.
Edited by AJ Sullivan
I wish someone had a video of the removal
So I can see how hard to pull
I have a new grill to install on my AT4... I'm dragging my feet cause it looks like a bitch...   Per the instruction, remove wheel well trim,   remove lower under grill trim, then as above....
  • 4 months later...
  • 3 months later...
Yeah I did mine last week. Got a paint matched AT4 grill to replace the stock chrome one on my 2020.
Took me about 4 hours (half that time was spent worrying about breaking something, so I was going super slow and cautious, realistically could be done in 2.5 hours). You've got 3 or 4 bolts on top part of the grill, and at the bottom underneath the trim piece beneath the grill are another 3. (I honestly couldn't get the bottom bolts out...so I ripped the grill out and those 3 bolts broke, which I'm extremely happy about because if I ever have to do the job again, its gonna be so much easier.)
In my opinion, there are way too many bolts and tabs all over these pieces. Since removing much of the front end, I only kept about half of the tabs and bolts. Making it so if I need to tackle the grill, it will actually be enjoyable.
1. Remove wheel well cover
2. Remove fender flare (I only removed it about half way, when I went to put it back together, i ended up pulling it all off, because you have to remove all the tabs stuck in the holes with a pliers to reinsert each one back in the fender, then push it back in.)
3. I know pics will be helpful for this and I can upload some if requested, but the bottom lip under the grill, to start pulling that up, starting from the wheel well area, there is an 8mm screw located in the wheel well area near where you pulled the fender up. Once you remove that, itll release that trim to be pulled on. Youll know where the screw should be located, looking at the line in the body of where the trim piece begins. You can start pulling up the big piece of trim that's the lip to the grill. Everything is basically tabs and push pins you yank out.
4. Once you have it all pulled out, lining up with the grill on the side you started with. If you have fog lights, disconnect the wire to them....now follow steps 1-3 on the other side.
5. Now once you have both sides of the bottom lip hanging, and only the center to deal with to detach it from the grill. I couldn't seem to get them detached. I had probably 4 tabs I had to detach from the grill and bottom lip together..after 45 minutes of frustration and a White Claw later....I got pissed and just pulled the grill hard towards me, SNAP!! Those 3 bolts I was saying were at the bottom? Yeah, their plastic surroundings broke. Which released the grill and bottom lip into my hands. It was finally removed!
6. Took the grill and lip inside, finished disconnecting the tabs that kept them together, and put the new grill on and plugged those tabs in. Carried it out, set it back on the bumper, pushed all the tabs and pins back in and then reverse installed everything! Viola!
  • 6 months later...
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,142 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
