Black/Unresponsive Screen
Owned our 2019 Trail Boss for less than a week and the Infotainment screen isn't working properly. At first, it was unresponsive to touch. It also didn't respond to selection of any buttons below the screen. Tried using the power button to turn it off but nothing happened. At first opportunity to pull over and turn the truck off, we did thinking it would reset everything. Now the screen is blank and the buttons still don't work. Will be calling dealership in the morning for advice but thought I would ask here first. Any suggestions?
You can disconnect the battery for 15 minutes and see if it comes back but best to take it in not working.
Im having issues with mine going dark as well but it usually re sets after an engine re start.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
