transmission problems 4l70e
just wanted to see if any one has any idea or clues in to why my trucks transmission would be acting up. it shifts from 1st to 2nd in a high rpm and then to 3rd just fine but not 4th gear, any ideas what it may  be or be causing it? the truck does give a code for a bad crankshaft sensor.
Maybe in limp mode - internal sensor of and the e cu is limiting damage. High 1-2 could be accumulator failure. Clutches could be burned out. . . .
Need to take it in and check sensors, solenoid, pressures, fluid etc.
