2000 chevy blazer interior electronics don't work with out turning on high beams
Chewy420
Hello, so I've checked all fuses and they all are good, replaced headlight switch and multifunction turn signal switch and still have the problem. Vehicle will start, however none of the interior electronics work, ie cluster, radio, interior lights, etc... Will only work when I pull the high beam switch and hold it, literally everything turns on like there's no problem, but only while high beams are held on. Please help ?
7 hours ago, mikedeezxxx said:
These trucks are notorious for bad fuse blocks. That would cause the problems you are having.
Even if all the fuses are good?
I'd try a hard reset - might get the stupid out of the BCM.
Hard reset = disconnecting the battery, and touching the positive and negative cables together for 30 seconds.
If that doesn't work, check all powers & grounds to BCM, any connectors, and the wiring for chafe points. If that all checks out, the BCM is probably done for.
It’s usually a broken wire inside the fuse block. Have you tested every fuse for power going in and out? I’m very familiar with this issue in 2006-2009 trailblazer SS’s. Electronics start acting wacky, the usual culprit is the fuse blocks on those.
I shall try this, thank you
Tested every fuse and all good, so far no broken wires.
On 6/15/2019 at 8:03 AM, silveradosid said:
when you hold the highbeams on are the headlights bright or very dim
I would say that their brightness is normal for high beams
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
