Has anyone else experienced noise similar to whistle or ringing between 35-50 MPH on new body style Silverado? Mine is Crew Z71 RST. It is at dealership getting looked at and they claim there IS in fact a bulletin however no fix yet. Want to know if anyone else experienced this and if there is a known issue. Can be heard windows up OR down more prominent on the drivers side and truck is generally warmed up at time of noise...
Thanks!
There's a thread on this and I believe it was a fuel tank/filler neck vent line issue? There's a service bulletin listed on the thread.  Sorry didn't have time to browse through the threads. Someone will chime in on the link.
Edited by mafd2
As the previous person mentioned, there is a thread...I believe it was in the troubleshooting forum .
I had the noise. If I remember correctly, the vent line on the fuel filler neck was either too narrow or it needed reinforcement as it would collapse on itself causing the whistling noise.
My entire fuel filler neck assembly was replaced under warranty and it solved the problem.
Found another thread that I see others are experiencing the same issue. Hopefully there is a fix from GM soon. This is the noise^^^
Yes, this is the fix. I had it done on my truck too. It is a known issue and they will replace the parts.
  • 6 months later...
Thanks!
Did you get this fixed yet?
Thanks!
Have you gotten this fixed yet?
I have a similar sound coming from the dash of my 2019 1500LT 2wd. First heard it while it was parked in garage. Sounded like a bird so I ignored it til I realized it was the truck. Could it be a low battery warning?
20200328_100252_Normal.m4a
Edited by Tim F.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
