weird sound when driving, not normal at all
ok yeah guys this is extremely hard to explain online but the best thing i got is a video, please watch it and anything helps my tranny temp is normal tire pressure normal engine feels normal when stepping on it but it’s just when i cruise like around 30-50ish i hear it
thanks anything helps! taking it to dealership ASAP while warranty is still good I SHOULD ALSO ADD that it’s coming front passenger area. https://youtu.be/raDVKR_fcxo
That is weird.   Where does it sound like it's coming from?   Does it only happen on bumpy roads?
no man, in the video i was in a smooth road. and front passenger area, checked under to see if anything was under nothing, 2014 silverado double cab. really scared tbh this truck my boy :sick:
I'm sure it's fixable. Us it 4x4? Probably a cv joint or something simple like that.
no sir just bone stock 2wd 5.3, yes hoping it’s some small going to jack it up right now and see if the wheels is shaking
2 things and it will sound redneck but have someone fallow you and see if the wheels shake or bounce. then have it up on a lift and check the tie rod and steering then all bushings. last would be to check the tire balance. Some times the tires have to drive through a bad balance and at a higher speed you lose the issue.
sounds more like an good idea lol!! but quick question how can i check the tie rod, steering and bushings? i know lifting it and shaking the wheel to see if it’s lose is a sign for ball joins but what about other ways to check for those components?
