Ok, So we all know AFM lifters have been known to have issue and I have seen a lot of people post tricks, or preventative maintenance, or the most farfetched information I have ever seen in my life explaining why they tend to go bad. So, With that being said. I thought I would give my view on what I have been seeing and what is causing the lifters to fail.
The first thing and most important thing is… MAINTNANCE! If you fail to service your truck like you should, you will definitely have an issue. I would really recommend not using the oil life monitor and changing your oil every 4000-5000 miles. You can use Synthetic or non-synthetic oil if you follow this schedule.  Oil has come so far from 10 years ago that regular oil is not that different (as far as breakdown and effectiveness) than synthetic oil.
The AFM activation and deactivation is controlled by the VLOM (valve lifter oil manifold). It has 4 solenoids that direct the flow of pressurized oil to the AFM lifter when controlled by the ECM. Now this is why changing your oil is key. The filter underneath the oil pressure sensor controls contamination from clogging AFM lifter. If the filter gets clogged from trashy oil it will cause low flow to the AFM lifter and cause it to fail. The amount of pressure the AFM lifters need to operate is 25-65 PSI of oil pressure. It needs 22 PSI of pressure to unlock the pin releasing the Lifter. This is why proper maintenance is critical.
That’s the main cause of the lifters failing, even though many other things can cause it. Modifying your ride height of the truck can cause an over activation issue. Poor fuel quality will cause the same. Larger tires causing engine strain causing over activation and the obvious… Faulty parts. Everything is man made and prone to fail at some point.
Just wanted to put my 2 cents out there. I will also link a video to the removal procedure for replacing the AFM lifter. I am working on another video for the installation now. I hope this information is informative and helps someone!!
  • 4 years later...
Very telling that you have not received any comments. I don’t think that those who trash these engines online want to admit it’s maintenance and modifications that cause the failure. No doubt bad parts exist, but there has to be more to it than “junk” design.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
    • I just did a little bit more research, and it seems that this Avalanche is not a Global-A vehicle, because the charts seem to list several models that were Global-A starting in 2010, but the Avalanche is not on there. And even similar models such as the Silverado are not on the Global -A platform until later in 2013. Please correct me if I'm wrong.
    • Yes, the 2007 is a GMT 900. Originally I had ruled out computers/compatibility as a problem because I did not change over any computers, only the engine. I know that the motors are different codes, but it seems like the lmg to lc9 is a fairly common swap, at least from what I can read online. I'm using all the wiring and sensors from the 2010 vehicle, as well as the computers (the only exception to that being the MAP sensor).
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
