Where to get these harness retainer clips
Does anyone know where I can get these gray wire harness clips?  This type appears to be made like a zip-tie with the "Christmas Tree" style push-pin.  They are used throughout the engine bay and I need to get some more.   If someone just knows the official name so I can Google it, that would help too!  Thanks.
afe-magnum-force-stage-2-pro-dry-s-cold-air-intake-matte-gray-14-17-5.3l-w-electric-cooling-fan-5.jpg
You can also reuse if the tree isn't damaged. Just cut the zip tie strip off at the head and run a new zip tie through the head of old zip tie.
I reuse them all the time if you are just replacing it with the same size harness. All I do is stick a tiny flathead screwdriver in the bottom end where the zip tie ratchet is and it spreads it open a little and then I just take a small pair of pliers to pull the zip section back through to unhook it. Then just remove the screw driver and feed the tie section back through the opening and it will lock back down.
afe-magnum-force-stage-2-pro-dry-s-cold-air-intake-matte-gray-14-17-5.3l-w-electric-cooling-fan-5.jpg.ffe47567bcdf25eb81d2787bd4c3c226.jpg
I’m going to go through my stash tomorrow if I I have some I’ll send them to ya!
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,452 Guests (See full list)
