Has anyone removed these?
Specifically what I want to know, are these basically 3 pieces stuck together?
6.2L plate stuck to the black plastic piece stuck to the grey bezel and that all is clipped to the fender or is it all one piece that cannot be separated?
I think they’re a single unit.
I had looked at spares to get for a custom project but they were a little pricey and didn’t want to blow $250.00 for a “guess”.
Theyre $120 from your dealer or $80 from gm parts direct. I ordered an extra set and sent them off for modeling for custom badges. I didnt even open the box though so i cant answer the original question
Before I ever saw a 2019 I read they were vents with something up front that opens at speed still have not figured out what they talking about but the engine does run cooler than my 2014.
I was bored today so I removed the wheel, inner wheel well and reached up there with pliers to release the clips to remove the vent badge. It's non functional and unless you use a dremel to cut away the plastic welds, the 3 pieces isn't coming apart.
I was really hoping it was taped on and didn’t have holes in the fenders.
4 hours ago, brianc636 said:
Well....that really sucks....
Yep. My idea for custom badges went out the window. I wanted to keep the bezel and remove the black piece to have a new badge made and insert it back into the bezel piece.
I don't want to have to buy a new one if I can't get them apart the way I need to.
Just by looking at it I'm not convinced all the tabs will stay on the backing once one takes a dremel to all the plastic welds to try to separate the pieces.
What if you try and remove the sticker portion from the black part? I was thinking if that would come off easy, I’d have new badges with AT4 made that look factory.
I tried getting under it with the edge of a razor knife and the way the black piece is molded around the edge where the 6.2L plate sits in there (recessed) I wasn't having any luck getting behind it and didn't want to mar up the black, so I gave up
You could likely get someone like Emblem Pros to make you a custom badge. Do the plain jane trucks just have a plain black cover? Other than that you would have to cut it out of the fender, weld in a metal piece, do body work and repaint. I think myself I would just leave it alone. imo
  • 3 months later...
Did anyone ever have any emblems made? I'd like to cover up the "5.3L V8" and just have it say GMC or something.
    CaptainDad
    CaptainDad
  • Who's Online   2 Members, 0 Anonymous, 649 Guests (See full list)
