Pre-Vortec EFI
Hey everyone. Saw a local school district pickup today. By the looks of the dash it was definatly older than mine (94) and on the tail gate it said "EFI". What motor would that be?
It was either a 88 or 89 TBI truck. Back in the day they were still proud of the fact that they had electronic fuel injection. Almost every vehicle from the period has a badge with some sort of FI note, even though nearly every car in production had some sort of EFI by then making it nothing special.
My dads '91 had EFI on the tailgate. It was a TBI 350!
You're right,
It was more years than just 88 or 89, but it does not denote engine size at all. I have seen trucks that say that with 4.3L and 5.0L too.
88-95 are the tbi years, Vortec FI started in 96; I took it off my 89 when I had it painted, represents the fi system not the engine size.
My grandpa has an '89 F-350 an it has an EFI emblem on it. At least the sticker is easily removed.
My 88 Chevy 1/2 ton 4x4 had the EFI decal. I had the 5.7 (350) liter engine.
My 91 S15 Jimmy has the "4.3 Fuel Injection" emblem on the tailgate. Thats pre-vortec. Throttlebody injection.
yea but TBI isn't EFI. Thats kinda strange. TBI is more like a mechanical fuel injection. So does that mean chevy kinda fibbed?
Nope, TBI is definately Electronically controlled fuel injection. Take out your glovebox liner and you will find the ECM behind it which directly controls the 2 fuel injectors in the throttle body assembly. Basically the same system from 87-95, few minor differences.
ok...so I need help. If my TBI motor is EFI, what is the big stink about a 350 motors vs. Vortec 5700? Wasn't the major difference the method of injection? Can someone point me to a reference that has the differences between the 210hp V8 and the 255hp Vortec?
Vortec is a completely different induction system from the air filter through the heads. I'll let someone else who knows better explain the ins and outs.
Starting in 96, when the vortec motors were introduced the fuel injection system changed to Vortec fuel injection which is basically one injector per cylinder. These motors also have Vortec heads which I'm not exactly clear on the differences with the prior version heads, I do know that the head design is different from prior engines as a TBI manifold will not bolt up to a Vortec motor. The bolting pattern is different. GM does have available a TBI manifold to bolt into a Vortec motor, I actually have one waiting to put a 97 motor in my 89 TBI truck one of these days, I've been contemplating this project for quite a while and just have to make the time to do it, if I ever do it - my old motor is still holding up ok. Vortec I believe refers to the fuel injection system which sprays a Vortex (tornado type) mist of fuel into the cylinder which theoretically is more efficient because the fuel is dosed more efficiently. So Vortec heads along with Vortec fuel injection yields the higher HP rating. Someone correct me if I'm wrong.
