17 vs 18 inch wheels
Z71-K9
I have a set of black 17 inch steel wheels that I ran on my 2012 Silverado in the winter time.  Anyone know if they will fit my 2019 AT4?  AT4 currently has the 18 inch wheels.
Doubtful. The brake caliper changed such that it’s closer to the backside of the spokes so there’s only one wheel Ive seen from the K2 (previous platform) that will fit on the T1. But if you have the means to do the work yourself give it a shot and see. If you aren’t aware, front & rear brakes are typically different so that’s something to keep in mind should you try to fit up on your own.
The diameter should work since some of the coilover manufacturers are putting 17s on their new 19s but like the person above me noted you will most likely have clearance issues with the brake calipers. You should be able to clear them with some wheel spacers depending on the style of wheel you have.
Sent from my ONEPLUS A6013 using Tapatalk
I was told by the dealership previous models wheel wouldn’t fit
I had a set from my 2010 I was hoping to use this winter.
I ended up getting the 17 inch wheels that come from with the WT model.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
