Some people.....
Yesterday I was in my uncle's Pawn shop wiring up his stereo display. This guy probably 19-20 years old comes in. I noticed he was driving a 2-door 4x4 Tahoe. I told him he had a nice looking truck and he asked about mine parked out front. Well we started talking about them and how much we liked the 2-doors. He asked if I ever took mine in the mud. I told him not this one but I went a couple of times in the 95 I did have. I told him the 95 was Z-71, 3.73 and locker rear diff, and would go like crazy in the mud. OK NOW HERE IS WHERE IT GETS GOOD!!!! He tells me that he has a shift kit in his (which is a 95 BTW) and when he puts it into 4x4 and punchs it from standstill it would pop a wheelie!! :lol: Ok, the intelligent conversation ended there. Then he tells me how he painted the 2-tone on his with spray cans. Which I know is total BS the finish was way too good for that plus it had clear coat on it. If this guy could paint that good with Krylon he needs to open a body shop. I don't know why he would even lie about something like that, did he think it would impress me? After the wheelie comment I had been looking for an out......what's that you need help in the back??.....ok, coming......
I don't know about the wheelie thing with just a shift kit. Maybe with a 572 Crate engine. :jester:
But the Krylon thing.....I have seem some people do some amazing things with spraypaint. If you sand, primer, sand, primer, sand, primer, etc. and then go with light, even coats followed by Krylon clear coat....It will yield some pretty impressive results.
Of course, by the time you do all of that, 427 cans of Krylon cost more than a real paint job that will most likely be a lot better.
I would seriously doubt the legitimacy of his Krylon Klaim.....I would have asked him to prove the wheelie, and offered him a 20 if he did it. With 4Lo, and and shift kit.....It's pretty torquey....I might have to try a wheelie next time I'm off road.... :rolleyes:
I can make the rear end of my truck lift up, if I put the brakes on really hard.... :rolleyes:
WOW!!! :lol: You too??
And I thought I was the only one that can do an endo in my truck! :jester:
:cool:
I can make the back end in mine come up by punching it while in reverse! :cool: Can't quite get the wheels off the ground yet, but I am still practicing :rolleyes:
:jester:
I don't know about the wheelie thing with just a shift kit. Maybe with a 572 Crate engine. :cool:
Yeah me too! I have worked in and around body shops since I was 16 (just turned 23) and I can tell you this was not a Spray can jobber. My 95 wouldn't throw you back in the seat much less pop a wheelie :jester: Oh well, now I know to just say "Hey, what's up" next time and keep moving.
I knew a guy that worked as a salesman at a Ford dealership. This was in the mid 90s or so. Anyway, he claimed the new Mustangs had a system that detected wheelspin and transferred power to the front wheels "via the brakes". He also said the new Probes had a 32 valve v6. And that his Ford Ranger would beat my car in a drag race because "his was higher off the ground and it aided weight transfer". Lastly, his friend's Jetta would also beat my car because the Jetta was heavier. I don't think this guy was paying attention during Physics class.
Yeah, will I am so skilled I can get my entire truck to jump off the ground while not moving. I can't tell you how though. It's a secret.
That guy sounds like an idiot. :rolleyes:
I just re-installed the Hypertech and put in some new MSD plugs into my Sierra. Now I can pop a wheelie! It's amazing what a few mods can do.
:rolleyes::jester::cool::lol:
I don't know about the wheelie thing with just a shift kit. Maybe with a 572 Crate engine. :rolleyes:
I don't think it would do it with a 572 unless it was mounted on the back bumper.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
