I have had a few z71 Denali 4WD trucks but with the 2019 Denali Ultimate Yukon it does not have hill decent. I don’t think Z71 was an option on this trim Yukon. Why I don’t know...even the Acadia I rented this week had hill decent and it is not even a z71. Anyway, I know it modulates the ABS individually by wheel and I have had to use this in ice situations when going down hill in a curve and worked great every time... passing by other vehicles in the ditch.
Has anyone tried to add it? Sometimes the pigtail is already there like the old DIC on the 07-13 trucks. Before I remove the dash, has anyone noticed if the pigtail is there? If so I can buy the button cluster from a Z71 Tahoe and try it.  I don’t know if a re-flash would be required either.
The problem with the Denali is they replaced the Hill Decent knob with the retractable power-step knob, but I don’t know if the system can still be activated on other way or not!
You are right... now how do I remove that trim to look for an extra pigtail and to see it it is an individual button or as a cluster group.
I will never need to disable the running board so I don’t mind removing that button.
The Yukon Manual mentions Hill Decent button... but I have not seen any offer it other than Tahoe (for this platform).
Edited by EXSlider400
Here is the Z71 switch:
To remove the switch trim/housing on the dash, it looks like it should just be snap in tabs but before I try it, I would like to know if anyone else already knows before I damage it.
https://www.gmpartsdirect.com/oem-parts/gm-tract-control-switch-23172141/?c=Zz1lbGVjdHJpY2FsJnM9c3dpdGNoZXMmaT1HQTE1MzgwNSZyPTcmYT1jaGV2cm9sZXQmbz10YWhvZSZ5PTIwMTcmdD1wcmVtaWVyJmU9NS0zbC12OC1mbGV4
I guess it is not only to disable the running board, but also to keep it open when needed like washing the car. It functions as a hold to the running board rather than disabling I guess.
I added the switch when I found the wires. I don't think the BCM is programed. Can HILL DECENT be programed in?
I don’t see why they would not be able to.  The vehicle already has the information for the degrees of center. I guess we need a technician to comment. I know my 2007 did not come with cruise control and I had them program it in after I added the parts.
It appears your vehicle may already have it...or what it’s evolved to - Powertrain grade braking.
Grade breaking is not the same as hill decent but they may share some of the same features.
I stoped this mod as I am trying to get a buy back because of the cabin pressure issue.
Grade breaking is different. I would like to keep this going. I would still like to find out if it can be programed in. Could mister White chime in on this?
I just have found out that this feature is listed at the RPO vehicle’s codes sticker. Look for it
(JHD) HILL DESCENT, GEAR HOLD
That sounds similar but different. It sounds like grade braking since it mentions “gears” because hill decent just modulates individual brake calipers. This sounds like when descending a mountain or hill at normal speeds it will keep the vehicle from speeding up (I forgot what this was called but I remember it activates after tapping the brake twice or something like that). Does anyone know of a Z71 RPO that specifies “hill decent”. I will see what mine says.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
