2019 Silverado 6.2L. This is my first DI engine. Been reading about the dirty intake valves and a catch can. Looking at the engine, I only see 2 short lines in total for the PCV system. Front driver side valve cover goes to top of throttle body. Passenger side front valve cover goes to air intake. Am I missing something? Is there another line somewhere? Is the PCV valve in the valve cover? I would assume on the driver side?
unless your running a supercharger, theres no point in filtering out the valvecover port to the intake. 80% of the oil consumption is thru the manifold to pcv port
Ok. Where is it at? I couldn't find anything but what is pictured.
i have a 2016 truck, yours is on the drivers side manifold ,and runs down to the engine valley area, near the water pump, uses quick release  fittings. it looks like a 3/8" pvc tube. you can make your own catch can just search.  try pulling the engine cover off  , the manifold has a pcv check valve connected to the pcv line.
Edited by flyingfool
Checked installation instructions for a catch can on the 2019+ 6.2 and there is nothing under the engine cover. What I have pictured is it. I see some people talk out the side of their neck.
the manifold cover sits on top of the manifold, i think its a heat insulator.. i have a 5.3, but the design should be same. take the  cover off! move some shit out the way , get in there will ya
Look at the upr catch can installation instructions. The PCV valve is in the driver side valve cover. Nothing under engine cover. Nothing in the valleys. 2019+ 6.2 must be different than yours and you assumed it was the same.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 765 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
