let the market mature... I know RI is working on a fog and grill setup...
other companies are slowly pumping out stuff as well..
as of now, there isnt a product i would use.
only potential option ive found remotly suitable is RI SR-Series.. it's about 1.2inches tall, one of the thinnest, high end bars available.  and its actually SAE compliant, so you can use on the public road.
nothing is worse than some idiot with a 50 inch light bar blasting 50,0000 lumuns down the interstate, blinding 20 drivers.
Need more fog options for sure. I think BD have one but they are so pricey. Want some amber fogs and then I’ll add perhaps a 20” bar behind grill.
On 9/24/2019 at 8:39 AM, Sotally Tober said:
Baja designs.  Wired into high beams.
Do you think that with those Baja designs mounts you could have fit a 30” bar behind the grill?????
So I’ve been in the works of installing 2 32” light bars for sometime. But like every new truck, they don’t make brackets so I custom made some. Don’t mind all the wiring. I just installed the amber lights and I’m still in the works on tucking in the wires for a clean look. Let me know what you think and how I can be of some assistance to you all.
Look's good - Any photo's of the grill off, or night photo's ?? Thanks
Not yet but I’ll post some tomorrow. The lights aren’t hooked up yet. I mean I have the wiring done but I was debating where to install the switch in the cab
I don't see why the BD kit will not work on my LTZ? The grille is the same "style" as the white truck posted.
There’s no metal backing close to parking break. that’s where I put my switch
14 hours ago, waverider969 said:
I have done something similar to my 2020 custom with one 22" Bar. I think it looks good but not sure if Im loosing lot of light behind the grill.
Not a fan of bars behind the grill. Losing light for sure
On 4/3/2020 at 12:32 AM, kye said:
40 oz usa osmar curved.  Fit really nice.
what kind of modifications did you do to get light bar to fit?
  • 11 months later...
I too would like to see how you mounted it. Please and thank you.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,881 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
