On 1/28/2022 at 10:26 AM, BlaineBug said:
Apologies in advance for reviving an old thread - but is there any concern with tapping into the ambient mood lighting?  I bought some LED strip lights, installed them, tapped into the mood lighting +12 volts under the passenger front footwell and added an in-line 5 amp fuse as well.  Seems to be working as intended.  The lights don't draw much power, obviously less than 5 amps as that's the smallest fuse I had on hand.  I did not use any relays.  These lights originally come with a cigarette plug that I chopped off.  The LED control box has a 12 volt input so there aren't any transformers in the cigarette plug that one would need to keep.  The wires in the wire harness for these LEDs are so insanely tiny there can't be any way the amperage is remotely concerning, my opinion of course.  Installed in a 2019 Yukon.  Tapped right into the ambient mood lighting harness +12 volt wire directly below the glove box.  Lights turn on and stay on when it's dark (which is determined by the light sensor and NOT controlled by the headlight switch) when the doors are opened or the vehicle is running.  Which is what you'd want as there's not much of a reason to have them on in the daytime.
Great question.  I have been adding a totally independent busman  fuse box and need to find a dimmable source wire to tap for the ambient switch lights. I put a 6 switch panel above the over head console.
Is my 2021 Silverado interior.  SMH.
I can't see why it would be a problem, especially if your backlighting needs are solely for those 6 switches!  For added protection throw in a fuse in-between the aftermarket switch backlights and the dimmable ambient lighting circuit like I did.  Something like a 2 or 3 amp fuse should be sufficient for such a low draw, and keeps your factory lighting circuit protected from this external (auxiliary?) light source so you aren't solely relying upon the factory fuse (which in my vehicle is in the driver side dash fuse panel.)
I do have to say that your brand new truck looks like a mess!  I'd be scared to tear it down like that.  I always have issues with broken tabs and clips no matter how careful I am!  It's always a frustrating nightmare with plastics for me.
Edited by BlaineBug
True about the plastic tabs.  Broke two in the whole tear down.  Nothing major, one I may replace from the pillar handle if it doesn’t seat back in well enough. The plastic is so much cheaper in the new chevys.   I am not new to tearing
I started looking for where to come through the firewall.  It came down to “one more” screw in a few areas to get to where the main harness comes through and decide drivers vs passenger side.  Turned out it helped with the whole project under the hood.  I plan to post a thread with what I did so far.  needed these switches for future additions or mods and for my BlackVue 900 cam and escort radar.  I like seem less integration.
 I plan to try your tap local for the ambient light for the switches, less than a amp draw… should be ok. If not, I will probably wire a independent dimmer for that and other future ambient lighting upgrades.  Truck is 1.5 months old or so.
  • 3 months later...
On 2/7/2020 at 6:25 PM, Smoothbassman said:
This is easy.
Get you a strip of LEDs and tap into the dome circuit. When you open the door lights on.
If you pull too much current then the BCM will trip out so go light in the LEDs and you should be OK.
Sent from my SM-N960U1 using Tapatalk
What if I tap to the dome fuse, will it to the same? I don't want to tap into factory wires. Thank you
This is easy.
Edit: sorry for posting twice, it's my first time here
Edited by sddud
  • 2 years later...
On 9/15/2019 at 6:45 PM, Smoothbassman said:
Ok after testing most of the wires in the BCM I finally found the one that I need to make this whole thing come together.
Pin 10 on the forward most BCM connector gives me the positive output for the dome lighting.
After testing the Opt 7 lights I found that I can't turn the courtesy lights on without the main light controller on so I'm going to have to rethink the electrical. I'm currently running it on accessory power and that's not going to work. I need the power to come on when I open the door, and be active when I'm rolling down the road. Going to have to add some relay logic to get this thing working the way I want.
More to come this week.
Is Pin 10 B+ then?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
