Borla GM Performance exhaust 19329322
NE-KID
Hello everyone,
Can someone tell me how is the sound from cold start up and idle and moving? I'm looking in to getting this exhaust for my 2019 Tahoe LT Z71 with the 5.3L V8.
If you are looking for something factory performance sounding it is a good option.  I have it on my 2018 6.2 and wanted a performance sound, not too loud.  Cruising around you can't hear it at all which is what I wanted.  It doesn't drone really at all except sounds a little funny with the AFM v4 mode which I deleted with a tune.  There are ways you can do it that won't mess with the warranty and AFM doesn't make a noticeable difference in fuel mileage anyhow.  I have a couple friends with stock exhausts that really want one after riding in my truck.  Maybe youtube borla touring cold start to get an idea.
I put borla atak duals on my '16. Sounds awesome (loud outside) and drone is almost nonexistent. Also, way cheaper than a "factory performance exhaust". I noticed on the GM Borla kit, it had the pressure actuated flap at the end. The borla does not (which i prefer).
Sent from my SM-G950U using Tapatalk
the Borla site has sound clips. Starting up and taking off down the road. I got my Borla for free for letting them make a video. If you tow you may want to stay away from the more aggressive mufflers as the additional rpm the exhaust is really working and can be loud on a longer drive.
Thanks everyone. I got the exhaust few days ago I get it installed this Friday I'll post my opinion on it. :)
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
