2018 Denali 6.2L 8 speed - cheat code...
I've had my Denali for about 4 months now and I've gotten into a habit that makes the truck more driveable for me, even if it's at the expense of a few mpg's.
When I put the truck into forward gear for around town, city driving, I slide the selector lever all the way to L and then use the stalk button to select 5 as the highest gear.  This keeps the rpm's right where I want them for city driving (under 50ish), prevents the unnecessary upshifting to gears 6-8, and keeps the power available for acceleration/re-acceleration without the need for a downshift and the associated delays.
Anyone else do this?  See any harm in it?
It ALSO keeps your truck in V8 mode. I have a 2015 6spd and it's never been in D. I put it in manual mode, then 5th gear every single day. 180k on the clock and zero issues motor wise. Trans was just rebuilt 5k ago, but I am tough on this truck. I just dropped it off for a new exhaust system actually, so I'm confident in it enough to put more money into it!
Sent from my SM-N975U using Tapatalk
All you are doing is staying out of overdrive. The 2 down shift is still there. I would have to review that pattern in the 8l90 but sounds like you want a tune. Change the mph the shifts are at. Open up more power and remove dod you will increase power shift better keep mpg and not hurt your trans. Win.
I can get higher shift points just by engaging tow/haul mode and keeping the trans in L5.  The last thing I want to do is start altering the factory setup.  Too many headaches for me.
And although I CAN get downshifts if I lay into the throttle enough, I find that I don't need to do that if my RPM's are already up and I only need moderate acceleration.  It's when the truck is in 8th gear at 50mph that I need to kick down in order to get moving.
Not in my truck.  I wish it were that easy.  I still get V4 when in L.
6 or 8 speed?
And which gears, all or just the 6th or 8th depending on which one you have.
Hmm...not sure. I'm not a trans pro, but seemed to work for me.
16 minutes ago, surfcityz71 said:
8 speed.
What gear(s) do you see it in V4 while in manual mode?
9 minutes ago, surfcityz71 said:
I'll have to check next time I'm on the freeway.  Maybe I'm wrong.
You could be right, but if you are I think you have a problem.
I think as long as you are in manual mode 1-7, it disables the V4 mode, shifting to 8 enables it again even in MM.
Even more reason to never be in 8th gear!
