Hello all.
As some of you know by reading my other threads, I have been having seat vibration issues with my truck.
I am on my 4th set of tires and I think I finally found one that is a good combo of street comfort and still has a little bite for off road.
Went with E-rated: https://www.bridgestonetire.com/tire/dueler-at-revo-3
I had the Falken Wildpeaks AT3W and they required a lot of weight to balance. They are 61 pounds per tire, and these bridgestones are 48 pounds per tire and they're both E rated.
The bridgestones required very little weight.
Although my seat vibration issues have drastically been reduced with these new tires, I am still getting some seat vibration/feedback at anything over 65-70 mph even on the smoothest of roads.
Is this normal, especially for these bridgestone which are not very aggressive, even for an A/T tire.
I would appreciate the feedback.
Thanks all.
Edited by Sin City Trail Boss
Why E rated?  E's will ride like a brick, unless you're weighing them down with a load.
Unfortunately for this tire size they either have only P rated or E. I was a little worried about going P rated because I do off road on occasion, and was worried about getting tire punctures.
I have 90 days to try these out. Wonder if I should go back and get P rated ones.
I will say these ride a lot smoother than the Falkens. I still have seat vibration, but it's a lot less than before.
I had non E range wildpeaks on my 2015 and could not get rid of the vibration. Half the reason I switched to the 2019 (other have was the wonky 6spd shifting)
Running the factory tires on the factory 22"s and have a little seat vibration still. Just had the dealer road force balance and it is better but still there sometimes. Seems worse when I let the truck sit for a couple days.
My truck has the same shake with stock everything.  Since the shake is at the bottom of my list compared to the other issues I haven't had the dealer look at it yet.
Seems like 99% of larger tires size then stock only come in E load. Big reason why I haven't upgraded.
The only time I had almost zero vibration was when I switched tires with my buddy.
It was his stock 18" wheels and tires. Same size as what I have now, only P rated and they were street tires.
I wonder if this is just a normal thing for this truck? I figured since the tire I purchased is not very aggressive at all, that I would have zero vibrations, but I have seat vibrations even in the smoothest of roads once I hit 65.
  • 3 years later...
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 230 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
