I changed out my console lid to one with storage but there is no organizer available for the jump seat type console so I made one on my printer.
I have the .stl files for these if anyone has access to a 3Dprinter.
  • Like 12
I was tossing around the idea of designing and printing an organizer for my jump seat console but if you already have an stl file you’re willing to share I would like to get a copy.
14 hours ago, matthewthughes said:
We have one at work can you send me the files?
Sent
Please send me this file as well.
I would suggest posting it to thingiverse and then posting a link here. The more people posting these designs, the better it is for all of us T1 owners.
Nice job sir.
This is outstanding! I love the way 3D printing is revolutionizing the way we solve problems.
My son is in the process of printing one up for me right now, it will be a two piece (due to the size of his print bed) but it will sit in the slot's on the top part of the console.
Edited by TweetybyrdRT
spelling correction
Anyone willing to make me one of these? I will pay of course but I don't have anyone that I know that has a printer and this looks awesome.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
