On 10/18/2019 at 10:59 AM, saber said:
I changed out my console lid to one with storage but there is no organizer available for the jump seat type console so I made one on my printer.
I have the .stl files for these if anyone has access to a 3Dprinter.
First, great job!
Second, if you're interested in selling one, and can make it in black, please let me know as I would like to buy one.
Thanks!
Hi there,
    Cool organizer. Could you please send me the file. TIA
  • 5 months later...
  • 5 weeks later...
I joined this forum just for this post.  I would love to get these STL files if anyone has them available.  I'll probably end up modifying the different sections a bit so they hold what I need them to, but ensuring I have the proper dimensions are what I'm really after!
Thank you, OP, for making this!
@saberIf you still have the files, I'd suggest uploading to Thingyverse.com so people don't have to keep asking here. If it's uploaded there, a link can just be shared.
my son's print went really well for the unit he designed for me (bucket set model) , had to be a two piece due to print bed restrictions and it fit prefectt until it got really hot outside....  PLA shrinks when it gets too hot.   he reprinted with ABS and no more issues.
  • 3 months later...
  • 4 months later...
  • Who's Online   2 Members, 0 Anonymous, 360 Guests (See full list)
