lost my door speakers
ksenter
Noticed that I have lost my front door speakers.  May or may not be a bigger deal than I'm making it.  I'll have no trouble replacing them if they're a direct problem of themselves.  I suppose my thread is to determine if this is a common issue or is it possibly related to anything else?
Both the rear speakers and both the dash speakers are operable, but have lost both front door speakers.  At first it seemed intermittent, but now they never work.   I have a non-bose system with the mylink system.  I havent made any recent changes prior to this occurence.  Using the fade, I was able to confirm the rears work and the dash speakers work, but no doors.  Sucks, what little bit of bottom end/bass the truck had is all but gone.  Truck is a 2014 silverado LT Z71, non-bose.
About a month ago I had the RCDLR and BCM replaced trying to get the TPMS/remote system back up and running, to no avail.  I dont suspect this is in any manner related, but information provided none-the-less.
So first let me say the fade isn't true. As the rears are mid range speaker and act like a 2 way component to the front doors. But still moving on the front doors are easy to replace. Just go to a website like crunchfield and order harness, mount plate and speaker.
thankyou for your reply.  I'm not in the least bit worried about the replacement how-to's and/or difficulty, but again (not being ignorant or arrogant) thankyou for the reply.  My main concern is, is there an issue other than speaker replacement to be concerned with or is this most-likely just the speakers themselves?  Very possible they went out at separate times, but getting neither left or right door speakers seemingly gone at the same time seems as though it could be input related.
Any recommendations for non-powered (off the HU) good definition and solid bottom end replacements?
Could be one speaker gone bad and affecting the rest but i highly doubt no sound out of them will be remedied by replaceing them. Sounds like a bad module or speaker. Did they all just stop working or one blew and you kept playing?
Sent from my LG-G710 using Tapatalk
at this point I couldnt give an answer to that.  I suppose its possible that one went before the other but not that I was able to determine.  Thats why I'm hesitant to jump straight to ordering replacement speakers and calling it done.  I'd love to order some replacements and that be the end of it but want to rule out the possibility there's a signal problem or something else going on first.  Only way for me to know for certain is to pull the panel and see if I'm getting voltage/signal to the speaker itself and maybe use a known good speaker to determine otherwise.  So is life
Pull the panels and disconnect the door speakers and see if that changes anything. If so well...[emoji106]
Or pull the codes and see if it list a speak. Sounds crazy but on my truck it shows sub out of circuit range.
