SIlverado 1500 towing capacity
My family and I have begun looking at travel trailers. Of course the RV dealers will gladly sell us something that is way to heavy for me to pull, and I so I'm trying to due my "Due diligence." I have attached my build sheet that was provided by GM and my 2018 Silverado owner's manual.
Something that is throwing me off is that the owner's manual  (pages 302-317) does not show a 3.08 axel ratio matched with a 8- speed transmission.
Appreciate any help.
2018 Silverado - Build Sheet.PDF 2018-chevrolet-silverado-owners-manual.pdf
Thanks for the reply.
I have to question how accurate those calculators are. The VIN decoder they use shows my truck as having a V6 motor. That's completely wrong and a disqualifier for me.
If that's wrong. Then contact a dealer. They should know
Sent from my motorola one zoom using Tapatalk
I have the big sales brochure from my 2015:
For a Crew Cab, short box, 2WD with 5.3 engine and 3.08 axle, it says max conventional trailering is: 6,400 lbs.
It might vary by a couple hundred pounds for 2018, but its close to that.
edit:
now I found it in your owners manual, page 305, middle of the page.
You also have 6,400 lb max trailer weight.
I agree that the 8spd should make a difference over the 6spd.  I'd give GM customer support a call/email and find your towing capacity.  I would also look at your payload posted in your door.  This will also be a consideration when selecting a trailer.  There are many nice "lighter" trailers on the market that will be within your towing limits.  I pull a dual axle 22 ft. Winnebago comfortably with my V6 (albeit 3.42)
I agree with aseibel's post, don't think it makes a difference between transmissions with the 3.08 rear end.
That gearing is just not set up to tow much weight, more for gas mileage.
I don't know.  Didn't they change the max tow from 3.73 to 3.42 when they went from 6 spd to 8 spd?   I am not arguing but I believe increased gears may have an impact.  Hopefully our resident experts will speak up ?
edit:
Thanks, for being a second set of eyes. I wish they would have included the 8-speed transmission with 3.08 axle in the list.
Disregard prior info.
Silverado with the eAssist option that you have is 6500lbs max trailering capacity with 2wd.  That is with the 8 speed and 3.08 gearing.
If you had 4x4 and the eAssist package, you would have 3.42 gears and the 8 speed, with a tow capacity of 9100lbs.
Order guide tow page here:  https://www.autopartners.net/apps/eogld/NASApp/domestic/proddesc.jsp?year=2018&regionID=1&divisionID=1&type=0&vehicleID=20987&section=trailer_specs&page=&butID=8
no problem. I'm guessing it was omitted because it does not make a difference. You are limited by your axle ratio. I have a 4WD with the 3.42. My max trailer is 9,200 lbs. I only have 6 spd tranny.
7 minutes ago, newdude said:
8 speed with 3.08 is not a possible combination.  If you have the 8 speed, its either  3.23 or 3.42 rear gears.
But his build sheet lists both of them:
M5X - 8 SPEED AUTOMATIC TRANSMISSION
GU4 - REAR AXLE 3.08 RATIO
LOL that's what I get for not clicking the sheet.
So OP has an eAssist truck...that would explain the 8 speed/3.08 gears.  I've corrected my post above.
Although it's not the news I hoped for, I believe I have accurate information now. I'll start looking for a 5,120 (6,400 X 80%) GVWR travel trailer. Just last weekend I had the folks at a local RV dealer try to sell me trailers with up to 5,800lbs dry weight.  I wonder how long my transmission would have held up in the Texas summer heat pulling those weights?
Thanks everyone for your input.
You need a different truck. Even with a small light travel trailer that thing is gonna be a dog with that 3.08.
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 525 Guests (See full list)
