Your '19/'20 Acadia impressions
We often "discuss" going to a one vehicle couple.  I'm a pickup fan and her comfort is in small, "practical" cars.  The Acadia appears to be a respectable compromise and she will probably be fine with it if the price is right.   The problem with compromises is that sometimes nobody turns out happy!  I want to be proactive as we just sold our travel trailer and my arguments for keeping the truck are weaker than ever!   I'm confident that there are members here who have downsized to a mid-sized SUV and hoping you have some insights to share.
I just read that the Traverse is basically the same as the Acadia but roomier.  I am also seeing the Hyundai Palisade as a possibility.  It has more of a traditional "Suburban" type style that I like.  Downsizing homes and vehicles is something many of us are fortunate enough to face.  I rank the prospect of going to a single, smaller vehicle right alongside a prostate exam.  I don't look forward to either, but know I'll be better off in the long-term!   I know many members have already downsized their stables and would appreciate hearing opinions.
We have the same issue. 2015 Silverado and 2017 Acadia. Both have needed  warranty work and if we had only one vehicle, we would be stuck renting at our expense. Keeping two vehicles.
Yes, it is very seldom that we both need to drive separately at the same time.   However when these occasions occur, they are significant.   Admittedly, I also like having a vehicle I can call my "own".  After 40+ years of marriage I know everything is "ours"  but  using the terms his and hers appropriately helps to keep a relationship healthy!
  • 1 month later...
Hey fellow BC guy...
Mostly on your note of this going to a small practical vehicle... the Acadia is not a small vehicle IMO. Perhaps a bit smaller compared to a pickup (never owned one, rarely driven) or a minivan (owned 3, either the wife or winter vehicles). But definitely not small regardless.
That said I came from a Z06 / minivan (late fall to early spring) combo, and am very happy with the Acadia. My wife drives a Rogue, which I would actually consider a small vehicle, one that you would likely not want as your sole vehicle (nor would I).
Let us know what you decide on.
  • 4 weeks later...
We have both a 2017 Denali Acadia (my daily) and a 2018 Enclave Avenir (wife) (same size as Traverse).   Also have 2 full size trucks etc. I would say if you are downsizing from a full size truck, I would lean towards the traverse/enclave over the Acadia/XT6. I do like the Acadia and only got it because I knew we were going to upgrade my wife from her old Enclave to the new one so I did not want 2 of the same vehicles.  They get about the same gas mileage but the increased size for the 3rd row and the trunk has us using the Enclave more when we do family things, even if we are only using 4 seats. the trunk on the acadia/XT6 with the 3rd row up is pretty small.
If looking at Traverse, also consider the Enclave, yes a little more expensive, but comes with a longer warranty and better resale (also we think it has nicer finishes).  We actually got a better deal on her enclave than my Acadia so it was only about 1-2k price difference (found a local dealership that actually had better prices than the previous one outside of St. Louis that I had purchased the last 4 vehicles from).
Hi Grant, I have a question for you about your Acaida.  Please check your message box.
Thanks,
Steve
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
