Service trailer brakes system (Truck will not move)
GM had an issue with the service brake controller at times. Should not keep the truck from moving.
Are you hooked to a trailer? If so unplug the trailer from the truck and move it.
Not hooked up to a trailer, truck will not shift into gear. It is stuck in Park. Truck runs fine but will not move at all even tried shifting with truck key in ACc position
