Are you going to PPF the sides of the trucks to stop the rock chips or put on flares?
Sad thing about doing gears is that it will costs you an insane amount of money just to re-calibrate the computer correctly. And that's on top of the cost for new gears.
Can’t stand flares. But I have new fenders ordered. Hoping they only take the quoted two weeks to be made and shipped Then I’ll have them painted and put them on. They have a 3 inch bulge so should cover the tires well. And again not overly concerned on gears for the time being. The 8 speed honestly seems to shift better with the larger tires that stock
lapoolboy I really appreciate your opinion. I remember when I shat on your truck??
anyhow, if anyone wants more specs or pictures just let me know. I will add, that I am running 2 inch wheel spacers in all of the pictures. These trucks are just way too skinny from the factory.
  • 3 months later...
I’m working on a project to do a 6” front and 4” rear and want to go 35” tires (Either 295/65r20 or maybe 35x?) if possible on stock wheels. What tires are in these pictures? What if any issues did you have with rubbing, and did you run any wheel offsets? With the lift I’m planning it kicks the front wheels out about .25” and was going to run 1.5” wheel spacers to clear spindles/links, etc... Which puts me at about a -28 offset and was wondering what kind of rubbing issues I’m going to run into. Thanks for any insight.
So your truck will be squatting? Please dont say so...
6.5” front and 4” rear is actually level. Ideal would be 6” front and 4.5” rear if I can find them. If not might do 5” rear to leave some rake. That’s not the point of my original question though thanks for pointing that out...
with that setup, you should have no problem running 35's
On 12/6/2019 at 11:59 PM, 19silverrado said:
Why, why, why?
I guess I didn’t pose my question clearly. 1. What  make and exact size are the 35” tires shown on the stock wheels? and 2) with those tires and 2” wheel spacers how much rubbing/trimming is required with a 6” lift? Thanks.
To answer your question in all the pics I’m running the 6” rc lift all the way around as it comes with the addition of 2” drop shackles and 1/2” front top strut spacers as well as 2” wheel spacers on all 4 corners. That setup on 35’s is 35 12.5 20 on factory rims. The new wheels are 37 13.5 on tis 944’s 20x12 with -44 offset. The 35 setup barely brushed the felt fender liner. The 37s rub the bumper and fender lightly at full turn. This is why I’m doing the glass fenders and bumper spacing.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
