ABS Scanner
I'm looking for a bi directional scanner to bleed an ABS module on a 2001 GMC Savana van.  I replaced all the brake lines and must bleed the ABS before the normal bleed routine.An Autel MaxiCheck Pro won't do it.
Thanks
Ron
I bought Autogenuity w gm enhancement to do my truck, and it worked fine for me.
And the overall process for bleeding the brakes is (at least, for '04 it is):
-bench bleed MC if it's gone dry (can do this in truck as well)
-bleed all 4 corners, started with wheel furthest from MC to nearest
-perform the ABS bleed procedure
-bleed all 4 corners again, in the same order
