I added these MGP Caliper Covers to my Black Friday order at Summit Racing.  I installed them this weekend on my 2019 Custom Trailboss.
They install super easy and add a bit more of that accent red to the truck.  Thought I would share if anyone has seen them and wondered if they work.
The front clearance is very close. Roughly 1/4".
Pretty spendy for a "glamor cover", but to each his own... ?
  • Like 5
16 minutes ago, TrustyDusty said:
I will definitely be looking into this for our Z71 next spring.....thanks for the pics and info?
4 minutes ago, dane0254 said:
That looks pretty good. I will definitely look into them. Any issues with them?
I have only had them on one day, but I don't foresee any problems. Clearance in the front would be my biggest concern,
I’m trying to decide whether I should paint the current stock calipers or go with the red covers for my black RST.
Does anyone have any photos of stock wheels with painted calipers or caliper covers?
The MGP caliper covers are actually powder coated aluminum, not plastic. They are $250. That being said I ordered them red and custom with the Z71 logo in black. I’ll post pics after I install them.
That is bad then. To me they look like the fake plastic ones. Again, get what makes you happy. I myself think painting factory calipers looks better. Ones painted from the factory look even better.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
