Not finding much how to make the lights work with the interior lights. I looked up the schematics and got it all to work.  Looks ALOT better now. If you want to do it its easy.  The hot wire hook up on the bcm is on the first connector(white one) which is connector X1 and pin 23.  When you pull the connector off you will see a grey wire in the very bottom corner. The wire you want is the grey wire two over from the corner grey wire which is pin 23. I ran the hot wire from the bcm up to the drivers side light and tied in another hot to run to the drivers side. I also ran the ground over to the pass side and tied into the pass light and ran the ground right to the firewall. You will see a ground wire already there. For the pass light I cut some of the bottom cover back right where the  push pin is in the middle.  My lights I used has magnets so I just stuck it to the metal plate right under the cover I cut back.  I will attach some pics.
  • Like 6
  • Thanks 4
Thanks for this info- I’ve been unable to find this info anywhere!  So...do these footwell lights go on and off with interior, or do they stay on when dash is lit?  And I think I understand...the + wire connects to the gray wire to the gray wire only.....?
many thanks....
many thanks....
Yes it is hooked into the dome light control wire on the bcm so it operates with the interior lights and fades out when they do.  Yes only the positive wire hooks to the bcm grey wire (x1 pin 23)  and the grounds are ran over to the ground post at the pass feet.
Can I get a link to this kit?
58 minutes ago, Darth Potatoes said:
Which kit did you buy from here, if you don't mind me asking.
I bought a 12 light kit for my rzr and had 2 left over. They sell them by the singles also.  They are all the same light in all the kits. I just got white but they do have RBG now too.
Awesome thank you! Your setup looks really great.
I have the below kit installed, but I can't find how to make it go on and dim off with the dome lights.  It has an "aux" wire from the control unit, but wasn't sure where to tap the gray wire.  The wire you are talking about, is it on passenger or drive side?  When you say "tap" into it, are you referring to cutting and splicing the aux into it or something else?
https://www.amazon.com/gp/product/B00OU5LOT2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It is on the drivers side at the bcm,  If you look under the  drivers side under the dash you will see the bcm, it will have 7 plugs all in a row and they are all different colors.  The very first one is white towards you or the drivers seat. It has a release tab at the top and just pull it down. When you unplug it pull it down towards the floor where you can get to it better. You will need to peel some of the black felt tape back so you can get to the wires better.  On the other end from the release tab you will see a grey wire in the very corner. Go over to your right to the next grey wire and that is it.  That is pin 23.  Those are the only 2 greys in the connector.  So dont tap into the very corner wire and your good.  lol   I peeled the black felt back and used a T tap to tap into the wire.  This will make it fade in and out with the interior lights if your rbg controller will let it.  T taps need to be the red ones.  And ground to where ever. I ran mine over to the pass side floor.  There is a ground post right there.
Edited by Mudcon
This is exactly the information I needed.  Does the gray wire that you are T-Tapping into provide power as well?  Right now I'm getting power from the passenger fuse box via a spade and an empty fuse.  Its a constant power so I have to use the remote to turn it off when I don't want it.
Assuming that the gray wire is providing power, do the footwell lights power on when you turn the dome light on manually (like door closed and you want to turn the dome light on to be able to see)?
Just do it....LOL  yes the grey wire I said provides the 12v needed and works with everything for dome lights.  When you mash the button above they also come on. When you open the door they come on and fade out.
  • Like 3
  • Haha 1
Thanks!!!
i popped under there today and saw exactly where you are talking about.  I’ve got non stop rain and a not big enough garage, so I’m going to knock it out Sunday.  I’ll let you know how it goes!!
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
