I would like to do this as well, but I just want the footwell lights on when the headlights are on.  I just need a small amount of light in the floorboard.  Is there somewhere I can connect these lights so they are one when the headlights are on?
Thanks!
On 12/28/2019 at 4:14 PM, Mudcon said:
Not finding much how to make the lights work with the interior lights. I looked up the schematics and got it all to work.  Looks ALOT better now. If you want to do it its easy.  The hot wire hook up on the bcm is on the first connector(white one) which is connector X1 and pin 23.  When you pull the connector off you will see a grey wire in the very bottom corner. The wire you want is the grey wire two over from the corner grey wire which is pin 23. I ran the hot wire from the bcm up to the drivers side light and tied in another hot to run to the drivers side. I also ran the ground over to the pass side and tied into the pass light and ran the ground right to the firewall. You will see a ground wire already there. For the pass light I cut some of the bottom cover back right where the  push pin is in the middle.  My lights I used has magnets so I just stuck it to the metal plate right under the cover I cut back.  I will attach some pics.
Hey I have a question because I’m a little confused. I have the op7 aura pro kit. Here’s the link http://www.opt-7.com/aura-led-interior-lighting-kit/
it has a fuse tap on one side and two wires for the auxiliary. I’m trying to wire it so it turns on with the dome lights and turns off when I leave the vehicle. As well I would like it on when my headlights are on as well. If I put the fuse tap on a fuse that uses rap and wire the auxiliary wires to the dome lights will I get what I’m looking for. If not any ideas on how to get this to work. Thanks in advanced.
  • 1 year later...
Bringing this back to the top.
Thank you so much for all the information.
Yesterday I tapped 23 and installed footwell lights and they work brilliantly. Once the weather cools off a bit (90's yesterday), I'll get them installed for the back seat.
  • 9 months later...
Did you have to tap into 23 twice?  One for each side?
On 12/31/2019 at 10:00 AM, Mudcon said:
Yes it is hooked into the dome light control wire on the bcm so it operates with the interior lights and fades out when they do.  Yes only the positive wire hooks to the bcm grey wire (x1 pin 23)  and the grounds are ran over to the ground post at the pass feet.
Could you possibly post a pic of where you grounded?
  • 10 months later...
On 1/29/2023 at 1:58 AM, Klutch said:
Anyone know what pin on the BCM would be used on the '22-up refresh model?
I'd like to know this also.  I installed floor lights in a Wrangler recently but this is another animal .......
  • 1 month later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
