Tailgate cable broke
One of my tailgate cables broke today. Didn't do any damage since the other one held up. What is the part number?
Thanks for your help
what side is it? there are 2 different part numbers here they are
(i broke both :jester: about 6 months apart)
Tailgate Cable Drivers Side 88892973
Tailgate Cable Passenger Side 88892972
Bscott email me i have a nifty parts number page
Thanks for the part numbers. I ordered both cables tonight.
I just e mailed you for the parts number page you have.
Thanks again!
your email wont accept mine i got a mailer demon back
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
